Technical Section or How to fix it
Page 9 of 11 Previous  1, 2, 3 ... 8, 9, 10, 11  Next
Re: Technical Section or How to fix it
Post by Guest on 10/1/2009, 12:59 pm
I found that mine ran like a gutless pig on E10, but got the same sort of economy out of both unleaded and premium.BUT it didn't ping on premium going up a steep hill (Timing set on 6 degrees).
On a trip to Mudgee lately i got 14.2l/100km (50l to do 350kms) and that was sitting on 100km/h as much as i could.
Post by DRKNSTRMY on 10/1/2009, 1:08 pm
To add to the good points already listed,which way was the wind going? what was the road temp? sounds stupid but when i am at home on the farm we have and old hilux and it can take 5 mins longer to do the same trip with a head wind, also a higher road temp thins out the air which means more work for the engine for the same output. as for 98 vs 95 and 92 i only use 98 in all my cars, i used to work for bp and the difference in contaminants between the fuels was amazing, 98 goes under alot more filtration then 95 and 92, so not only do you get higher octane but you also get less shit clogging your engine
DRKNSTRMY
Post by wizard1 on 11/1/2009, 10:27 pm
thanx everyone for your thoughts yes we did have the spoiler on before yes there was a strong wind hitting us on the front right most of the trip did put new tyres on same size 245/60x14 same pressure 35psi put a new air filter on before we left and yes it was hot and brakes are all good i think we might just go back to using e10 and normal unleaded thanx again for the help wizard
wizard1
Post by Guest on 21/1/2009, 11:51 am
Wally needs his selectors replaced as they have worn, what i have is a slopy gate and cant select first gear if i canget it its right up near the dash 2nd is down by the bench seat
is that a good picture i have painted
well now can i get a new part or only a good 2nd hand, what are my options would repco stock them or rares??
WW
Post by Guest on 21/1/2009, 12:33 pm
That's a 3 on the tree isn't it Wally??
Post by Guest on 21/1/2009, 10:22 pm
sorry no a 4 on the floor
OZ wreck is closed till feb, need somewhere before then I am still driving about just taking of in 2nd
Wally
Post by Guest on 22/1/2009, 2:43 am
im not sure of the price but Speco does new shifters for all types a boxes and even do the twin stick for the aussie 4 speed aswell as the normal stick. or i think rare spares do one for a bench seat for about the $280 mark
Post by Guest on 22/1/2009, 10:57 am
thanks
Wally
Post by Guest on 22/1/2009, 11:31 am
He WAS only opening on Saturdays until then...
fuel usage
Post by wizard1 on 26/1/2009, 10:44 pm
looks like we might put a blown small block in the van as our trip to kandos was uneventfull until we went to the bowser 338km on 67lts and that was e10 i wiped clean the inside cannons before we left and apart from a little bit of start up moisture (condensation) they were virtually still clean no soot or the back bumper being black not like we we came back from summernats apart from that it ran like a charm thanx wizard
wizard1
Cam gears
Post by Ben79hz on 28/2/2009, 8:56 am
Has anyone had problems with camtech cams, fitted ont to my 308 but it will only run with about 40 degrees advanced timing, (2 timing lights used to conferm) and after watching when the rockers cross over on number 1 cylinder found it to be advanced the same as the timing,
Checked timing chain and sproket markings, all as per holden spec, 9 chain links from crank sproket markings to cam markings.
Just wondering if anyone has struck cams not suiting original camshaft sprokets, is the only solution to replace the sprokets with multi adjustable aftermarket ones ?
Ben79hz
Post by Guest on 9/3/2009, 12:07 pm
we have wb power windows there is power there but the switches are not working does anyone have any ideas on how to by-pass the switches just to get them working
Post by Guest on 9/3/2009, 12:14 pm
The motors are earthed internally.
Put power to one pin and the motor spins one way, put power to the other pin and the motor goes the other way.
Post by Guest on 9/3/2009, 12:23 pm
what i need to know is there a way of making a temporary switch till i can buy some new ones
Post by Guest on 9/3/2009, 12:26 pm
Do you have an old Semi-automatic aerial switch.(When you push the switch then let it go it returns back to the centre)
Post by Guest on 9/3/2009, 12:29 pm
yes he has
Post by Guest on 9/3/2009, 12:50 pm
Well put the power to the centre wire and the 2 wires which go to the motor , on each side of it.
#NOTE# this is NOT a long term fix as the switch isn't designed to use that much current through it.
Post by Guest on 9/3/2009, 12:52 pm
thank you agro woody will try it tomorrow
kerry
Post by Guest on 9/3/2009, 12:55 pm
No worries Very Happy
Tubbing out panelvan for 10x15" rims
Post by free_styler1 on 10/3/2009, 7:54 am
Hi
Just wondering if anybody has tubbed out the rear end of a holden van for large wheels?
Pretty keen to do so on the old sandman...
Any tips photo's guidelines etc would be muchly appreciated..
bounce affraid bounce affraid bounce affraid bounce affraid bounce affraid bounce affraid would like to keep the original lsd diff in the back without doing a rail/chassis tubbing....
Cheers freestyler1
free_styler1
Post by highwaymenace on 10/3/2009, 8:06 am
Brutle is a good example for you.. check out his post from his profile in the members list.
he has gone wild with his..
brutle tubbing???
Post by free_styler1 on 11/3/2009, 7:19 am
Sorry Daz
There's not a cracker in the members list on Brutle
It says in there that he's never even had a post...!!!!
Do you remember what forumn it was in?
Or was it before Vanning Aust - ie Southern Cross?
Cheers Allan
free_styler1
Post by soundman on 11/3/2009, 7:46 am
hey freestyler... here's a shot of Brutle's rearterior from 2007.
probably the post Daz was thinking of was from SXV and had some great shots of some of the work put into flaring the guards etc.
BTW is the sandman's body you intend to do this to already molested? there would be some people who would question the sanity of such a mod to a classic.
Post by highwaymenace on 11/3/2009, 10:50 am
sorry Free thought there was & Thanks SM for saving my a**
Post by Guest on 11/3/2009, 1:07 pm
woodvan wrote:thank you agro woody will try it tomorrow
kerry
So how did it go??
