Technical Section or How to fix it
Page 2 of 11 Previous  1, 2, 3, ... 9, 10, 11  Next
Re: Technical Section or How to fix it
Post by Guest on 22/8/2008, 2:33 pm
That's for that Dr.Interior. Very Happy
It'll be a BIG help i'm sure.
Post by mazdragon on 23/8/2008, 2:24 am
thanks guys. that's a great help. collecting as much info as possible at the moment so any feedback is really much appreciated. at this stage i'm only doing the roof and then i'll do the sides, as the van has windows which i'm not covering up. did you find the ply easy to bend without cracking, i've at the suggestion of 6mm mdf. I'll be toddling off to the hardware store in the next couple of weeks to see what's available.
thanks again. all going well i'll have the interior done by next nats.
Post by Guest on 23/8/2008, 1:32 pm
I was told to use 6mm for the arch and 3mm for the sides.
Post by Shagginwagon82 on 25/8/2008, 7:12 am
There is also another product on the market called "Pro-Ply" which is 9mm thick from memory. This is a purpose made bending ply. It will only bend one way but can produce a beautiful tight curve without any hassals. Being 9mm you don't even have to worry about screws pulling through when fixing it off. You may not get it from your local hardware so try Mr Ply & Wood or some other specialist.
Re Transit
Post by Big Bunny on 26/8/2008, 5:17 pm
Is there any sites etc with info on modifying Ford Transits I will hopefully be getting one sometime in the future and want to find out some info regards IFS V8 swaps etc I am talking early tranny's here the trouble is all the ones I find seem to be in QLD or full of windows Ive got no room and no time not to mention no money but stuff it I want a van again Very Happy Very Happy
Big Bunny
Post by billet on 27/8/2008, 3:14 am
Hi Guys, just got on here.
Thanks for the interior know-how, I now "know-how" to do mine, cant wait for the update
billet
Post by billet on 27/8/2008, 3:26 am
CURSED wrote:where do i go to get side pipes for my van
http://store.summitracing.com/egnsearch.asp?N=700+400002+115+4294847334
Brand: Patriot Exhaust
Product Line: Patriot Side Exhaust
Part Type: Exhaust Side Pipes
Part Number: PTE-H1175
Side Pipe Style: Lake pipes
Inlet Diameter (in): 2.000 in.
Inlet Quantity Per Pipe: 1
Outlet Diameter (in): 3.500 in.
Outlet Quantity Per Pipe: 1
Length (in): 73.000 in.
Accepts Internal Muffler: Yes
Muffler Included: Yes
Heat Shield Included: No
Brackets Included: Yes
Clamps Included: No
Side Pipe Material: Steel
Side Pipe Finish: Chrome
Quantity: Sold as a kit.
Exhaust, Lake Pipe 4, Steel, Chrome, Four 2 in. Diameter Inlets/One Functional, 3.5 in. Pipe, 73 in. Long, Kit
these pipes come in 63" 73" and 83" lengths, the length of my XC sills are about 84-85" MAX so I am considering the 73" ones. The XD-XE sills are shorter because of the shape of the front wheel arch so there is no way they will take the 83" pipes
billet
Post by CURSED on 27/8/2008, 4:09 am
thanks billet, ill have to measure the WB and look into it
Help welding
Post by shaginwagin on 28/8/2008, 4:49 am
Hi everyone, I need some advice, Had some rust in the centre of the passenger door of the Van. cut out the rust and cut a piece of metal to suit, tack inplace, all looks ok. When I went to weld it in fully, the surrounding panel buckled and warped something shocking. Sad Cut the weld and the panel straighten out to normal. Second try and did a little bit of welding then walked away until it cooled down, then welded the whole lot again, same thing. warped and buckled again Crying or Very sad Crying or Very sad . Have cut the welded piece out and the door is straight again but with a hole in the door (flow through ventilation),. HOW do I weld a piece in without the door distorting.
Julian
shaginwagin
Post by Admin on 28/8/2008, 4:51 am
call me and i will tell you the trick.
daz
View user profile http://vanners.newforum4u.com
WB Rear disc brake conversion
Post by shorts on 28/8/2008, 10:39 am
Folks,
I found myself some WB rear discs, axles and calipers / mounting to transplant into my WB van. Problem is I didnt get the handbrake linkages (from chassis to backing plate). Are they the same as the early commodores as chasing WB ones has been difficult. The original drum links are too long.
Cheers
Craig
shorts
Welding
Post by Guest on 29/8/2008, 2:23 am
Julian, as the weld cools the metal shrinks and this causes the surrounding panel to buckle. You need to stretch the weld as you go by flattening it with a hammer and dolly. Hammer welding is most common when using an oxy but it can also be done successfully with mig welding. Mig welds are more brittle than oxy so you have to hammer a little harder .... don't over hammer or the panel will buckle the opposite way.
With a mig, I spot weld the patch into place with 4 or 5 tacks and hammer them, then spot another lot of spots around the patch centrally between the first set and hammer them. I keep doing this until I have the whole patch spot welded in 10mm increments. I then lightly grind these flat so as not to build up too much heat. Spot weld again between each 10mm increment and lightly grind flat and then repeat until the patch is fully welded. Hammer all spot welds as you go. The process is a bit long winded but an amateur welder can achieve good results this way with a mig. Oxy is easier and much quicker once you master the technique of hammer welding.
Hope it helps,
Sean
how low
Post by pano on 29/8/2008, 5:28 am
ok i need some help with tyre size's and spring hights
iv got 215/65 on a set of 14's on the front and back and wot i wanna know is wot tyres do i need on the front and how low do i need to lower it to make it look something like this
iv been told the biggest tyre's u can put on the back at a stock hight without rubbing is a 245 and on the front is a 235
so i probably dont need to do anything to the back so ill wait till i get a set of 245's but as for the front i dont no wot to do scratch
so i need as much info as i can get on hights and tyre size's
this is wot it looks like now
cheers jake
pano
Post by Guest on 29/8/2008, 11:12 am
Jake if you want it as low as the green van thats about 2 inches, but 235s on
the front will rub, 225s would be better , Stormbringer is lowered 1 inch with 225 x50x15
on the front and 245x50x15 on back Cool
Post by pano on 29/8/2008, 5:13 pm
thanks stu
225's and lowering it 2 inchs it is Cool
cheers jake
pano
Welding
Post by shaginwagin on 31/8/2008, 6:28 am
Thanks Daz and Sean, I am doing a combination of both of your advise. I have only just started, done about a dozen spot welds at this stage and the panel hasn't buckled so must following your advice properly. Smile Small spot welding, then the hammer and dolly to flatten the weld, grinding it smooth, water to cool it down and walking away, thats the hard bit walking away and leaving it the cool down properly before I have another go at it. Will keep you posted, thanks again.
Julian
shaginwagin
Post by Admin on 31/8/2008, 1:00 pm
ya done yet Julian?
springs
Post by pano on 6/9/2008, 6:10 pm
does anyone know the torque settings for all the bolts on the lower wishbone on a hq/wb van? cos ill need to take it of to put me new springs in
and any advice on changing the springs would be a gr8 help.
cheers jake
pano
Post by Guest on 7/9/2008, 12:50 am
All i di when i did my Stato was to get a spring compressor to squeeze the spring up, undo the lower ball joint from the stub axle.
Slide the old one out and put the new one in.
I also used a jack to help keep the spring and lower wishbone in place whilst i di it all up.
Post by pano on 7/9/2008, 5:26 pm
thanks for that agro
it was a b@%#h of a job with no spring compressor plus i couldent get my ball joints to come apart so i ended up takein the wishbone off Neutral
cheers jake
pano
Post by Guest on 7/9/2008, 11:07 pm
Sounds like you had fun then. Wink Wink
Post by pano on 9/9/2008, 8:26 am
ahhh yer just abit
ok now iv had my tyres rub the inside of my gards on both sides whan i was turning out of my drive way Mad
iv got 215/60 one a set of 7 inch wide 14s on the front and i wanted to put 225s on Evil or Very Mad now i dont think i can
pano
Post by CURSED on 9/9/2008, 11:50 am
try 225/50/14
Post by pano on 10/9/2008, 3:16 pm
ill give that ago
does anyone know if 265s rub on the back at stock hight cos i was talkin to a bloke today that sed his hq wagon has 265s on the back lowerd 2 inches and it doesnt rub
he also told me about a blue panelvan in wyong that has 12 inch wid rims with 360 tyres on it Shocked now that sounds evil any one seen it ???
cheers jake
pano
Post by Guest on 11/9/2008, 1:21 pm
I supposed it depends on the rim offset.
I have 265's on the back of my van and when i get suspension travel it scrobs JUST on the outer edge.
I'll probably be going 245's to avoid problems (i could go 255's but i'd rather be safe then sorry). At least till after it gets rego'd and driven for a while.
