Millions K's out of reach!!!
Post by Vannin on 4/9/2009, 2:13 am
The van is finally getting a heart transplant!
1992 XF T5 manual.
831,392 KLM's on the clock.
I have had it since 94 when she had only 121,666 (mmm evil I tought too)
Has never had the head off it, engine itself has only had a waterpump replaced 12 months ago, mechanical fuel pump died 2yrs ago and replaced with and electric.
She's had power issues (or should that be lack of power issues) for the last 300,000k's and was really hoping to get her to the 1,000,000 k's....... Was going to put my reco'd spare in, but will save it for the Blue van, Going to put the Ghia Wagon EFI 6 (after a few mods and conversion to Carb) into her!
This week end, they will part company and while I at it the diff is getting changed for a Disc Brake LSD unit from an 87 Ghia Wagon.
So with any luck, I will be able to do hills and keep up with Wicked.
Re: Millions K's out of reach!!!
Post by highwaymenace on 4/9/2009, 4:00 am
dont work too hard.. lol..
PS: might be good for them little hills near Moruya hey.
Post by Vannin on 4/9/2009, 7:29 am
I'm never driving them hills without a diesel engine and jacobs brake.
I like to push my luck, commit suicide!!!!!!!
Post by highwaymenace on 4/9/2009, 8:28 am
chooken
Post by Vannin on 4/9/2009, 9:10 am
Bok Bok Bok Bokak!!!!
Post by SWAY on 7/9/2009, 1:16 am
hey john you could tow the trailer down as well. makes for good stopping!!
my van & trailer are still were you left it after the tow. i slack. Crying or Very sad Crying or Very sad
SWAY
Post by Vannin on 7/9/2009, 1:47 am
That is slack, I spent 3 hours running round trying to get gaskets, still didn't get any.
It's not like the thing is 40yrs old and a rare thing but no one has them in stock.
Ended up having to order them and wait till today for them to come in.
It's only a Falcon 6 cylinder, they never even had holden 6 stuff on the shelf.
So I spent the time trashing out the Ghia wagon for the bits I need, took Murray down to check out my WB Van (well almost mine)..... Needs alot of love but has great potential.
Have an engineer looking into a diesel conversion and all the legalities of it etc, etc, to see how viable it is and if it's worth doing.
Post by mazdragon on 7/9/2009, 5:37 am
someone's busy... Shocked
Post by highwaymenace on 7/9/2009, 5:46 am
sounds like it,, where the pics to prove it John? lol
Post by M&M on 7/9/2009, 11:54 am
Vannin wrote:That is slack, I spent 3 hours running round trying to get gaskets, still didn't get any.
John, would you believe I have some of them thar gaskets for a 250 EFI if you still lookin I thunk.
M&M
Post by Vannin on 7/9/2009, 12:29 pm
Thanks Matt, came in today & at a better price than they quoted..... it's a carb 250 with efi rocker cover (cause they looks pretty!)
As for pic's Daz....... I will organise some just for you in the daylight!
Still have to degrease the sucker again and slap some Dulux Reco at it, clean down the engine bay when the old one comes out, replace the pwr steer hoses (lots easy when no donk in the way), lots of little things but should be happening by Sunday now, nothing left to do but all the sweating!
Post by SWAY on 8/9/2009, 1:37 am
o well it will be worth it when it is done!!
i know the wagon was not running for over 10 months that was with 2 motor in that time.
good luck bounce bounce
SWAY
Post by Vannin on 14/9/2009, 2:41 am
This was not meant to be a happening engine swap, the Engine Gods are not smiling............
Broke bolts, EGR pipes would come free.......
But you can turn the old one over with one hand on the balancer with the plugs still in.
The replacement engine is an earlier model so the bloody cranks are different, so a late night flywheel and bolt hunt posse was organised and we got early flywheel & bolts...... only to have one of the pressure plate bolts break in the flywheel on assembly.....
and yes, I did have a heap of Ford Engine Blue laying around.... oil leaks should be easier to spot than a black engine.... then again, paint is on that thick a Dulux Reco would be proud.
Nude UP!
Post by SWAY on 14/9/2009, 3:27 am
thats motoring
i know what thats like!!!
SWAY
Post by highwaymenace on 14/9/2009, 4:04 am
Hey John, i maybe wrong but isn't that donk ment to be in that big hole in the front of the van?
Post by Vannin on 15/9/2009, 11:57 am
Well, finally the bloody thing is back in it's hole, Yes! where it's s'pose ta be Daz!
Just gotta plumb and wire her back up now, but that I'll be tomorrow night's excitement......
Post by Vannin on 17/9/2009, 7:51 am
Getting closer to the end..........
Just got a few bits left before turn key and pray time!
Starter Motor, Alternator, fanbelts & Radiator.
Been a bit under the weather for the last week or so I'm not pushing to hard, but as long as it's going for the Broadford run I'll be happy!
Getting more excited about the new van build...... every day something is developing with it.
Post by Vannin on 17/9/2009, 1:09 pm
IT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!
Gotta put the belly plate back on the front of the bell housing, flush the radiator, fix the weep at the back of the rocker cover.
Take it out n give it so curry!!!!!!!!!!! They "SWAY WAY!"
Post by highwaymenace on 17/9/2009, 2:10 pm
well where the pics.. come on John... we are waiting.
Post by SWAY on 18/9/2009, 6:53 am
remember,
i try to keep it all of the streets, well try to!!
SWAY
Post by ford351 on 29/12/2010, 8:53 am
gday did u put efi engine in one of ur vans
ford351
Post by Vannin on 29/12/2010, 12:10 pm
Van was 1992 Factory carb 6, T5 5speed...
donor, replacement was 86 Ghia Wagon EFI engine.
Swap over was easy... no as big a nightmare as I expected.
Only suprises were Flywheel bolt pattern, as late XF 4.1 engines use the later crankshaft.
Post by vanner065 on 29/12/2010, 2:06 pm
i know that problem with the fly wheeel hey John
Post by Vannin on 29/12/2010, 4:46 pm
Pretty sure I warned ya!!!!!! the old bottom end & crank will get good money with the turbo boys!!!
Did you keep it?
