Exhaust outlet
Page 1 of 3 1, 2, 3  Next
Exhaust outlet
Post by Guest on 19/9/2008, 3:59 pm
I took mine for a drive to Sydney last weekend and as my exhaust dumps just after the diff, the fumes came in from the tailgate.
Just wondering where you guys have you outlets and does the exhaust gas come inside?
I have got a few idea's where to finish it but curious where yours are.
Re: Exhaust outlet
Post by 70s-groover on 19/9/2008, 4:16 pm
If you dont want the pipes out the back then dump them behind the rear wheels, have had the old chevy drops on a few vans and cars and never had any probs with fumes, had exhausts coming out infront of the rear wheels as well and no probs, had 2 Toranas with the pipes dropped at the diff and bad fume problems with both, eyes stinging, head spins, got the pipes finished to the rear and all was good.
I dont think ending the pipes at the diff is the best idea, make them point out somewhere so the fumes can really escape instead of the fumes dwelling under the van/car/ute.
Hope this helps you Craig.
Cheers Aaron.
Re: Exhaust outlet
Post by 70s-groover on 19/9/2008, 4:21 pm
OH YEH, check the gap between the upper and lower gates, if that rubber is perished then you will get that fumes smell ( just remembered my old crappy HQ Van 6 pac i had, rubber on the bottom of upper gate was shot and let every smell in ).
Re: Exhaust outlet
Post by Guest on 19/9/2008, 4:31 pm
One of the ideas i have is to angle them out from under the rear corners.
Re: Exhaust outlet
Post by 70s-groover on 19/9/2008, 4:37 pm
Like this or dumping down ???
Re: Exhaust outlet
Post by Guest on 19/9/2008, 4:40 pm
Very close to that but having a 45 degree angle and about 2 1/2" pipes.
You'd only see the end of the tips sticking out by about 2".
Re: Exhaust outlet
Post by 70s-groover on 19/9/2008, 4:41 pm
sounds good, wouldnt cost much to get it done.
Re: Exhaust outlet
Post by Devilsgrip on 19/9/2008, 4:44 pm
What about when you drive with the taiul gate up??? Or do you?
Devilsgrip
Re: Exhaust outlet
Post by Guest on 19/9/2008, 4:46 pm
What i'll do is have a hotdog facing in reverse before the diff and a hotdog facing the proper way under the rear quarter with a tip on the end of it.
Because i will angle it down HOPEFULLY it won't matter with the tailgate open.
Re: Exhaust outlet
Post by Devilsgrip on 19/9/2008, 4:48 pm
I know you still get fumes in with the exhaust out the back as they get drawn in as you drive, but i dont know if you dump it behind the wheels???
Devilsgrip
Re: Exhaust outlet
Post by Guest on 19/9/2008, 4:51 pm
The only other way i had in mind was to face it ouwards from behind the wheels.
Only seeing about 1" of the tips
Re: Exhaust outlet
Post by 70s-groover on 19/9/2008, 4:53 pm
AGRO wrote:The only other way i had in mind was to face it ouwards from behind the wheels.
Thats how the ones on the HG are like now, you only see a fraction of pipe.
Re: Exhaust outlet
Post by Devilsgrip on 19/9/2008, 4:54 pm
that could work. How far back before the drivers door and passenger door do the dumps have to be???? Legal reasons?
Devilsgrip
Re: Exhaust outlet
Post by Guest on 19/9/2008, 4:55 pm
Do you have any pics that show them Azza??
Re: Exhaust outlet
Post by 70s-groover on 19/9/2008, 5:03 pm
just checking now
Re: Exhaust outlet
Post by Guest on 19/9/2008, 5:05 pm
I didn't mean tonight.
Looking at the time Azza, aren't you working tomorrow??
Re: Exhaust outlet
Post by 70s-groover on 19/9/2008, 5:07 pm
aha found 1, right near the drums, when the van is on all fours you can hardlly see them.
Re: Exhaust outlet
Post by 70s-groover on 19/9/2008, 5:08 pm
AGRO wrote:I didn't mean tonight.
yeh going now, gotta get up a 4.30am
Re: Exhaust outlet
Post by Devilsgrip on 19/9/2008, 5:10 pm
Fark go 2 bed seeya Shocked
Devilsgrip
Re: Exhaust outlet
Post by Guest on 19/9/2008, 5:12 pm
I'm off too so cheers cheers cheers
Re: Exhaust outlet
Post by Devilsgrip on 19/9/2008, 5:13 pm
see ya.
Devilsgrip
Re: Exhaust outlet
Post by Guest on 20/9/2008, 11:42 am
Won't the fumes still want to come in the back even though the exhaust just sticks out the side??
Re: Exhaust outlet
Post by 70s-groover on 20/9/2008, 11:48 am
didnt when i drove it home, couldnt smell a thing. Didnt drive with the gate up though.
Re: Exhaust outlet
Post by Guest on 20/9/2008, 11:50 am
I'll have a talk to my exhaust bloke once i sell the 4b and get the $$ for it.
Re: Exhaust outlet
Post by Guest on 22/9/2008, 3:11 pm
Probably up to $200 to get it done in 2 1/2".
Booked in for 2nd October so thanks for the tips.
Re: Exhaust outlet
