Replacing Sunroof
Replacing Sunroof
Post by 76shaggin_wagon on 10/11/2009, 12:57 pm
Hey all.
I've had the sunroof (old, pop up style) out of my van as it was leaky + fairly dodgily put in. Now its come time to put it back in, but i wasn't sure what product to use to seal it on install. Just wonderin if anyone who has put one of these in or knows anything about them could recommend something??
76shaggin_wagon
Re: Replacing Sunroof
Post by Guest on 10/11/2009, 1:15 pm
How would a SMALL amount of the sealant ,that windscreen blokes use, go around the metal's edge under the rubber?
Post by mazdragon on 11/11/2009, 4:43 am
the sealant, plus make sure the rubber is in good condition, the smallest nick will give u headaches of extremely wet proportions. It should also be a snug fit... Clark Rubber sell a variety of different profiles of rubber if you need to replace.
Post by pano on 11/11/2009, 10:27 am
at work we use a windscreen sealer called dab-off made by wurth it works well it doesnt dry hard but it goes firm
oh and iv found its hard not to get it everywhere so i suggest having a few rags and some wax and grease remover on hand Very Happy
pano
Post by 76shaggin_wagon on 11/11/2009, 1:32 pm
Awesome. I'll try and get a hold of some of that dab-off, it sounds like what i'm looking for. The rubber seems to be o.k, but i'll make sure i give it a good look over and check that its a really snug. It's good to know i can get replacement seal from clark rubber if need be. Thanks a ton.
76shaggin_wagon
Post by mazdragon on 13/11/2009, 12:35 am
if you do need to buy another seal, make sure you take the original one with you... they have heaps of different profiles and you can easily get confused.... well, i do anyway....
