confused....
confused....
Post by lozzie on 15/1/2010, 11:39 am
HELP!
I am not sure if my van is a HJ or HX
She has a HJ grill but I cant get to the compliance plates as they are covered for all the spraying etc...
I was told that there is only minor difference between HJ and HX ... And someone said that its a HX because of the indicator arm
If is was ORIGINALLY like an absinth yellow what could she be???
Could she possibly be a Sandman?
cheers guys
lozzie
Re: confused....
Post by lozzie on 15/1/2010, 11:51 am
I doubt it could be a sandman actually...i did a bit of looking up on the net... :/
Hmmmm
She has bench seat, column shift auto, single head light, 202.....can anyone help...
lozzie
Re: confused....
Post by Devilsgrip on 15/1/2010, 12:10 pm
She has bench seat, column shift auto, single head light, 202.....can anyone help...[/quote]
Wont be a Sandman with those. Sorry. Hard to tell about HJ or HX without looking at it,or looking at the tags. Over the years they all end up with a bit of each other on them at some stage. You can put a hj grill onto a hx, Hz etc. You could even have a HJ chassis with a hx body ??? who knows???
Devilsgrip
Re: confused....
Post by Guest on 15/1/2010, 12:57 pm
Can you see the numbers on the chassis rail?
Re: confused....
Post by lozzie on 15/1/2010, 4:13 pm
ill have to check....I might get the VIN number and call holden and ask Smile is that a good idea?
lozzie
Re: confused....
Post by Shagginwagon82 on 16/1/2010, 1:31 am
Hey Lozzie,
Easy solution is to ask to see the rego papers.
Re: confused....
Post by Guest on 16/1/2010, 2:38 am
look on at the wiring harness under the brake booster as it goes into the fire wall. if the wiring goes into a square box at the firewall. is HJ. if it goes into a round plug that looks like a press fit into the fire wall its a HX.
Re: confused....
Post by Pawso1 on 16/1/2010, 10:01 am
wow thanks van...I didn't know that one..cheers
Re: confused....
Post by lozzie on 16/1/2010, 10:17 am
yeha cheers ill check that out next time im at the factory! Smile)) thanksss
lozzie
Re: confused....
