blinkers not blinking
Post by wizard1 on 30/1/2010, 2:52 am
here is my other little dilemma lh blinkers all work rh side nothing yet with a test light checking the wires on the rhs the test light blinks right down to the light it self and even the original socket which is still there blinks but the 2 led lights and the frnt blinker which has a std bulb in it wont blink i thought i blew all leds and bulb but no because when the van is put in rev the lights light up any ideas thanx wizard
wizard1
Re: blinkers not blinking
Post by highwaymenace on 30/1/2010, 3:22 am
is the blinker relay can needing more load, as some are no good for leds.
Post by Shagginwagon82 on 31/1/2010, 12:14 pm
Yeah Wizard, I put LED light on the work ute and had to by a blinker resister for each blinker to add more load. Autobarn has these in their LED section.
Post by Pawso1 on 31/1/2010, 12:32 pm
Steve its your earth. The bottom of your blinker is where the earth bolts to the car. If the bulb is not flashing but your test light is, the difference is your test globe has a good earth. A common prob. As always ask agro about electric stuff, but adjust your earth, thats if I've read your question right.
Good luck buddy cheers
Post by Shagginwagon82 on 31/1/2010, 12:36 pm
Hmmmm, I read the blinker not blinking as the light staying on- that'll teach me to re-read the initial question......
Post by wizard1 on 31/1/2010, 10:30 pm
i will try the earth how come rev lights light up when they are the same row of leds as the blinkers and i had a led flasher unit connected blinkers dont stay on they just dont light up on rhs at all you put it in rev and the light lights up thanx for the help wizard
wizard1
Post by Pawso1 on 1/2/2010, 11:04 pm
So its the back lights, and your not running WB tail lights? If thats the case your rear blinkers should light up when your in reverse, which is what I think your saying. In that case your earth comes from the 3 mount bolts that bolt to your body, top middle and the hard to reach bottom. With the posotive wire check both sides are giving you power on both sides. They run from the drivers side to the passenger. If one stuffs up both could go. If you change you blinker wire to your brake light.....does it flash????? If so, the problem is narrowed right down... Shocked
Post by wizard1 on 8/3/2010, 5:08 am
i fixed the non blinking problem on the w/e after 3hrs of searching it was not in the rear blinkers at all it i put a new flasher can in it was the bloody frnt one causing the problem it was a earth problem now they work great thanx everyone for their help wizard
wizard1
Post by highwaymenace on 8/3/2010, 5:37 am
thats great news, now you can flash everyone when ever you like.. lol alien
Post by highwaymenace on 8/3/2010, 5:38 am
ps: mine dont work at all.
