Having probs with peeling paint (windscreen surrounds)..
Post by Odd_One_Out on 2/2/2010, 10:17 am
I got some peeling paint from my upper windscreen surrounds...
Was sanded back with 400 then primered before Satin Black (having the same probs with my door handles)...
My mechanic said the only way is to get them sand-blasted.
Any tips from you guys?
Odd_One_Out
Re: Having probs with peeling paint (windscreen surrounds)..
Post by Guest on 2/2/2010, 10:42 am
i rubbed mine back and got them powder coated. most places need cover both sides to make it last. but getting them back on is the real fun part. instead of your hand to bang them back on the clips. you need a small soft rubber hammer and a rag to cover the mould. give them a firm whack and they will pop back in place. or just pop them off and paint them every 6 months.
Post by highwaymenace on 2/2/2010, 11:23 am
Scott ( shagginwagon82 ) will set you on the right path as Van said Powder coating..
paint no stick
Post by Mans Ruin on 2/2/2010, 3:09 pm
try sanding them again, then use etch primer as it grips onto bare metal, then use normal primer, top coat, and a satin clear wouldnt hurt to protect it.
Rick
Mans Ruin
Post by Odd_One_Out on 2/2/2010, 7:40 pm
Yeah they were etch-primered and yeah they`re a real bugger to get off and on...
I`ll try the powder coating this time, hopefully it`s the last time.
Odd_One_Out
Post by Guest on 14/2/2010, 9:22 am
Most of the time the paint will flake due to poor surface preparation. you need fine scratches in the metal for the paint to Key too. Etch primer will create a chemical bond and the fine scratches create the mechanical bond. Correct application of 2 pac paint is almost as durable as powder coating.
