disc brake sals 4 my panno
Post by Mans Ruin on 6/2/2010, 1:05 pm
gday everyone, im in need of a disc brake 10bolt salsbury to put in my panno as i have been told by engineer that i need to have discs all round for him to pass my injected 5ltr conversion.
Mans Ruin
Re: disc brake sals 4 my panno
Post by CURSED on 7/2/2010, 10:21 am
try another engineer
Post by Guest on 7/2/2010, 10:30 am
I've never heard that one before.
Post by Guest on 7/2/2010, 11:01 am
Ring vicroads, they will be able to tell you whats what.
Post by Guest on 7/2/2010, 12:24 pm
you should be able to get the rear brakes and get the axles with the disc and hand brake cable to bolt under your pano diff housing from a prem or statesman. the rule in NSW about 4 wheel disc is because your going the injected 5L. the V8 c'dores have discs all round. you dont need disc all round if you bolt up the injection on a red 308. by the letter of the law in this state. you must meet the pollution laws for the engine block. use a red block and really dont need cats either. thats why i have unleaded top end on a red block.
maby injection not so good
Post by Mans Ruin on 7/2/2010, 2:07 pm
hey all, according to the 3 engineers ive managed to get info out of without stumping up cash first, because my van is 1)Unregistered, and 2)a factory six, because of not only the cubes upgrade but the injection i have to run th 4 wheel discs, also the rule about going by the emissions to suit block eg. hq block, that law has changed (at least in vic) now you have to meet emissions to suit that motor, cats, charcoal canister, unleaded filler on fuel tank etc. so its either disc rear (plus like 1200 friggin dollars for certificates) or bugger it all of and go back to carby. Crying or Very sad Mad Shocked bom
Cheers Rick
Mans Ruin
Post by Ltd van on 7/2/2010, 11:49 pm
I went thru the same isssue with the injected 5 litre in the XF Ford and after ringing just about every engineer on the RTA list found one in Sale that said the convertion i was doing was ok if you want I will try and find his number and post it for you
Ltd van
Post by Vannin on 8/2/2010, 1:16 am
Most engineers will op'd for a better performing braking system if it was easily available for the model.
My XF, 351 conversion.... required Rear brakes changed from drum to Disc, that was 1988 it was done.
Disc arse ends are an easy and straight forward change as most of you are aware. Just sourcing it is the issue.
I would kick and scream if they wanted 4 spot calipers or over the top Brembo's fitted..... to all 4's.
I must say, the van stops a hell of a lot better with 4 wheel disc than any onther XF I have ever driven.
re disc conversion
Post by Mans Ruin on 8/2/2010, 2:48 am
yeh it is hard to get a disc setup, also ive heard that there is issues with handbrake brackets fouling on leaf springs.
a friend suggested getting a borgy out of a ba falcon ute as they a suited to leaf springs, or even a borgy out of a vn vp bombodore and modding it to fit (mounting bracket, track etc)
And yeah Ltd, id like that engineers number from sale, thatd be sweet as.
Thank everyone
Rick
Mans Ruin
Post by Vannin on 8/2/2010, 3:03 am
The engineer that did mine is in Bayswater if it's closer to you than Sale.
More opinions the better!
Post by highwaymenace on 8/2/2010, 4:15 am
call Ken McGarg ( engineer ) in Mirbo ( think the spelling right ) 03 5664 8278
Post by Ltd van on 9/2/2010, 9:51 am
Ken is the one iwas going to give you and the spelling i have is Ken Mcharg so one of us has to be right
Ltd van
