Power steering bracket spacers
Post by shorts on 2/3/2010, 5:29 am
Hi,
Can anyone tell me the length of the spacers (3) for the power steering pump? These are the ones that space the bracket away from the head (driver's side) and I believe are between 3.5 and 4 inches.
Cheers
Craig
PS yes this van will see daylight eventually
shorts
Re: Power steering bracket spacers
Post by Guest on 2/3/2010, 1:00 pm
show a pic of the pump your using. they can sit different depends what its off.
Post by shorts on 2/3/2010, 1:34 pm
shorts
Post by Guest on 3/3/2010, 1:52 pm
that looks like an old pump from a commodore. and when its bolted up it leans slighty to the drivers side. i have one like that and i used a 30mm spacer. before i got the spacer i went to the local bolt shop and bought about 15 nuts and a hand full of washers that fit over the bolts that hold the bracket in place and spaced out what i need. the nuts i used to space out the bulk was 10mm. you may need slightly more of less depnding on what crank pulley your using also.
Post by shorts on 3/3/2010, 3:04 pm
It is on the drivers side but the spacing has to be over 60mm. I made up some 60mm spacers and the belt did not line up. One way I tried measuring was telling me about 100mm
shorts
Post by Guest on 4/3/2010, 4:29 am
what crank pulley are you using. say j x and z power steering spacers are about 45mm long. being 100mm long you would end up with too much flex. you would snap a bolt and or go thru alot of belts.
