The Zed is Dead
Page 2 of 2 Previous  1, 2
Re: The Zed is Dead
Post by Rusty McCrusty on 27/7/2012, 9:21 am
Thanks Daz!
Here is an update on the rotisserie!
Up and rolling!
Both up and rolling!!
Bored out some steam pipe to suit the roller bearings.
Notched the SHS to suit the steam pipe
Rams mounted
Bearings for easy rotation
Set up for centering the pano
Arms welded and mounted also the mounts from the K-Frame
Passenger side
Drivers side
Need to make the rear mounts, finish off the centering system, make and fit the rotator locking set up
Rusty McCrusty
Re: The Zed is Dead
Post by highwaymenace on 27/7/2012, 11:35 am
wow thats the best rotisserie i have ever seen
Re: The Zed is Dead
Post by vanner065 on 5/8/2012, 8:31 am
Excellent stuff Rick, man u got some work ahead of you but doing a great job so far, keep it up
Re: The Zed is Dead
Post by Rusty McCrusty on 29/9/2012, 3:38 am
OK Here are some more update pics!
Up in the air!
Needed to cut some rust out and weld some patches in the windscreen area.
Roof stripped back to bare metal, treated and painted with epoxy etch primer.
Start working on the lower quarter.
When I stripped the lower quarter back I noticed there was a panel welded over part of the inner section, removed that and found this!
Bent up a repair panel out of 1mm sheet.
Cut out the rusty section.
Will need to patch these areas as well.
Hammered in a rough profile to match and welded the repair panel in.
There wasn't much of the lower wheel arch left.
Made up a new piece and welded in and ground back.
Next on the agenda is replacing the drivers side lower rear quarter and making the inner a mirror image to the passenger side, I bought a couple of panels off a guy on ebay who makes rust replacement sections.
All this section was a chunk of bog!
Started cutting back to fit the new panels.
Looks like the rear beaver needs replacing as well, I have been toying with the idea to fit a wagon rear beaver!
Rusty McCrusty
Re: The Zed is Dead
Post by Crackers on 30/9/2012, 12:48 am
I've done a few rust repairs on vans.
but OMG, great job
Crackers
View user profile http://www.aurorarvs.com.au
Re: The Zed is Dead
Post by vanner065 on 30/9/2012, 10:06 am
great work Rick, amazing effort so far, keep it up
Re: The Zed is Dead
Post by Rusty McCrusty on 9/12/2012, 9:12 am
Thanks for the comments,
Back into working on the T,
Fabricated a rhs section for the rusted piece that the beaver is welded to.
It will be replacing this piece.
A couple of different views.
Welded in the replacement lower side section to make it even on both sides.
Another view also a bit of a hole to fill from a fair bit of rust I cut back.
Next I un-stitched the rear quarter panel for better access for repairs and for my replacement panel.
A NOS Quarter Panel.
Need to fill in the gap from the replacement panel.
Cover panel stitched in.
Fabbed a section to tie the support to the panel.
Welded in.
Patched the section in the wheel tub.
Welded in a new piece for the inner for the lower section of the wheel arch.
Decided to go with the original colour which can be seen in the last pic "Oasis Green"
Cheers
Rick
Rusty McCrusty
Re: The Zed is Dead
Post by vanner065 on 10/12/2012, 10:41 am
Mammoth effort Rick, glad you know what your doing
Re: The Zed is Dead
Post by Rusty McCrusty on 10/12/2012, 12:16 pm
Thanks James
Sometimes I know what I'm doing the other 95% I'm assing it Very Happy
Rusty McCrusty
Re: The Zed is Dead
Post by Sponsored content Today at 1:37 pm
