gasless mig welding
gasless mig welding
Post by azwon on 5/4/2010, 2:19 pm
hi, new to this, loads of fiberglass experience but this is my first attempt at the real thing.
bought a mig off ebay, gasless, but having trouble one getting things to stick and blowing holes in metal,
my other brain says maybe holding the trigger too long? has lots of splatter too,
would love some pointers, cheers
Re: gasless mig welding
Post by Guest on 5/4/2010, 2:28 pm
turn the power down some if you blowing holes
gasles mig welding
Post by Anchorage on 5/4/2010, 2:37 pm
HI AZWON what type of welder,has it got amp dial or low and high switch .Another reason can be wire feed to fast for splaters but rember it is aflux coated wire so it will splater some.For blowing holes it comes from speed to fast no bonding to slow and you get holes also you hold handpiece on slight angel and weld away from the start. Practice on some old clean metal. hope this helps
Anchorage
Post by Ramble on 5/4/2010, 2:54 pm
Try back-stitch welding for thin panels.
if youve got a seam thats say 25cm for example, start about an inch to the right of the left side and weld back to the left. then go to the right again past what youve done and weld back to weld you just completed doing an inch or two at a time, continue like this and it will not overheat the metal and blow holes and also keep distortion to a minimume.
above all ,practice and you'll get the hang.
gasless mig welding
Post by azwon on 6/4/2010, 11:27 am
thankyou all for the help, i think i need more practice with this, but i have learned more now, have lots of tricky bits to do, roof ect, but i want it permanent, cheers and thanks again
Post by Guest on 6/4/2010, 2:14 pm
cranbourne west ain't too far from hampton park so if you need some hands on pointers you can head out my way and i can run you through the processes of various welding techniques.
Gasless welding is quite messy by nature and just requires more clean up.
PM me if you want some help.
Cheers
