wb diff
Page 1 of 1 • Share •
wb diff
hi. just wondering the best way to get disk brakes on the back of my van? was looking at just getting a whole new diff, but read somewhere that the statesman disk brake diffs would not fit the van?
i would be probably more inclined to head towards upgradeing the whole lot as ill be running a v6 in the very near future. any suggestions on a good course of action? lol
matt
matt
mr sinbin- Posts: 69
Re: wb diff
have seen a one tonner with wb disc diff , he said you have to put handbrake cables left to right , right to left , i'll try to get an email addy for you
azwon- Posts: 119
Re: wb diff
found it, email this ebay id, tell him the guy who brought the 3 mags sent it to you, he has the details on wb diff, hope this helps
azwon- Posts: 119
Re: wb diff
thanks heaps for that azwon. ill flick him an email, see what i can find out! thanks again
Re: wb diff
I put a Disc brake rear under my HQ pano. Got a diff from a wb stato. The motorvation for the change was the 2.60 ratio as I was about to do a long long trip. Worked a treat, but there is a fair bit of dickin around to get it right. Hand brake cables are a major problem. In the end I'm glad i did it, but only just
Pawso1- Posts: 62
Re: wb diff
does anyone know if it is possible to convert the original drum brake diffs in wb vans to disk brake. my old man thinks it would be able to be done, but hes never done it before. has anyone done this and know how hard it is\what exactly you need to do it?
because i would think it would be a much cheaper option then buying a complete disk brake diff.
Re: wb diff
Yes.
The Wheel Studs need to be replaced with longer ones as the Discs are thicker then Drums. Side effect is that it increases your Track, which can be an issue with Wide Wheels.
Then you need all the bits exluding the Diff and Axles.
I bought a complete HZ Statesman Disc Brake Diff Assembly which I have since swapped over onto 2 other Diff Assemblies.
Rusty!
www.MajesticVanners.com
Rusty!
Rusty62TransAm- Posts: 183
Re: wb diff
also im pretty sure you have to use the booster/master cylinder out of the car the disc brakes are from. saw a wb 1 tonner with a vn commodore diff under it, just had to add correct brackets to suit leaf springs, i think by doing this it sorted issue with handbrakes
Mans Ruin- Posts: 56
Re: wb diff
Sorry I forgot.
I didn't have to change the Booster or Master Cylinder, only the Proportioning Valve.
Rusty!
Rusty!
Similar topics» wb diff
» Hiace diff G162
» Diff Locks ?
» WANTED: 2.60 or 2.78 ratio diff
» J30 VISCOUS DIFF 6 BOLT $100
» Hiace diff G162
» Diff Locks ?
Page 1 of 1
» the reincarnation of crystal wizard
» Sundowners Cruise Back in Time
» VAN INTERIORS
» MENACE Update
» 2013 Van Nats
» 2012 VAN NATS OVER & DONE
» EASYROLLER UPDATE
» Budja Budja - Halls Gap - June 2012 Queens Birthday Weekend
