reverse light problems
Post by mr sinbin on 7/12/2010, 12:33 am
hey guys
having trouble getting my reverse lights to work, not sure why they arent. i tryed chasing the wires but the gregorys i have is for a hz not a wb and the wire colours are different. does anyone hav any wiring diagrams for a wb that they could scan and post on here or something or tell me the coulours of the reversing lights\how they work and what they run off?
mr sinbin
Re: reverse light problems
Post by HJXX7 on 7/12/2010, 12:50 am
Auto or manual? Floor shift?
From Old holden .com
Column Shift Manual Gearbox Reverse Switch:
On Column Shift models the Reverse Switch is mounted above the Steering Column at the Firewall inside the Car.
Column Shift Automatic Gearbox Reverse Switch:
On Column Shift models the Reverse Switch is inside the Neutral Safety Switch. The Neutral Safety Switch is mounted on the top of the Steering Column at the Firewall.
T-Bar Automatic Gearbox Reverse Switches:
On T-Bar Automatic Gearbox models the Reverse Switch is inside the Neutral Safety Switch. The Neutral Safety Switch is mounted under the centre Console and bolted to the T-Bar.
3 and 4 Speed Floor Shift Manual Gearboxes:
On 3 and 4 Speed Floor Shift Manual Gearbox models the Reverse Switch is bolted to the Gearbox and activated by movement of the Selector Levers.
HJXX7
Post by Vannin on 7/12/2010, 8:24 am
With age many of the switches are failing (some just dirty contacts inside switch).
Locate the switch and make sure it is functioning 100% before worrying about the wiring!
In most cases it will be a switch or switch adjustment issue!
Wiring in the old Holdens is pretty good (even old as it is), its quite often only the connector plugs that will let you down!
Post by AGR071 on 11/12/2010, 11:41 am
How did you go?
Hope you got it sorted o.k.?
