wheels questions
wheels questions
Post by mr sinbin on 7/2/2011, 5:09 am
just wondering if commodore rims will fit on a wb panelvan? i heard off someone that the offsets were wrong but then read somewhere that they wer the same, so im just trying to clarify
mr sinbin
Re: wheels questions
Post by Vannin on 7/2/2011, 10:23 am
offset is slightly different and you may have to bore the centre out slightly!!!
Commodore wheels tend to jam onto the centre!
Post by AGR071 on 7/2/2011, 10:49 am
mr sinbin wrote:just wondering if commodore rims will fit on a wb panelvan?
No they don't.
They will slide onto HQ - WB stud pattern but wheel nuts wont locate correctly.
HQ - WB PCD (pitch circle diameter) is 120.mm
VB - VZ PCD is 120.65mm
They WILL break wheel studs.
Post by vanner065 on 7/3/2011, 10:41 am
Wow Agro, you are a bag full of knowledge.. cheers
