Hellovapano
Hellovapano
Post by hellovapano on 18/6/2011, 3:18 pm
Hey guys we have just picked up a 1995 model XG panelvan. Bit rough around the edges, not too bad in the rust department but had been in a prang on the back left hand side. Anyway as all good pano drivers know before you do the outside you start inside
Anyway pictures are better then words so here they are:
New Head unit
Left windows down when it rained which is why there is a towel on my seat lol
JVC 6x9's for the door - temporary installation
Materials for the back install
Starting on the floor
Starting on the wheel arch covers
More arch covers
coming to the tail end of the first cover
Dummy Install
Dummy install with lid
Starting on the second arch cover
Got it pretty close to the arch's so not much space lost
Got too dark so this is as it stands as of tonight...
hellovapano
Re: Hellovapano
Post by hellovapano on 18/6/2011, 4:03 pm
I also have a venom red BA xr6 and an XF ute but needed a new body shape for a project haha.
Will finish off the interior then it will be onto the body work and then ill need some decent power to move the 10 ton of timber in the boot ha.
Body will get a new respray of a dark metallic purple with lightning airbrushing in typical panelvan styling.
Im also trying to chase some old school bubble windows for the side and rear but if i cant find any ill either make my own perspex ones or weld up the holes completely and go windowless.
Engine wise ill probably do the same as my old ED, shaved head, au gasket, crow cam stage 3, tune, pacey extractors, custom dual exhaust etc etc.
Have 2 inch lowering bloack for the rear and lowered front springs from my ute, just a bit worried i might be too low on the front but ill cross that hurdle when i get to it
Also have a 3:4.5 LSD which will find its home behind a chrome diff housing
Just for a bit of wank factor here is a picture of my ute:
hellovapano
Re: Hellovapano
Post by vanner065 on 22/6/2011, 2:19 pm
Gidday and welcome aboard. A bit of a handyman i see with the wood, keep at it, i will be interested to see what you have planned for it. By the way your ute looks great, keep at it.
James
Re: Hellovapano
Post by hellovapano on 23/6/2011, 3:51 am
Hey thanks for the welcome,
Well the two arch covers are now done, just awaiting the two 2800watt powervox amps to arrive so i can mount them inside the boxes. On the weekend I'm hopefully going to nock the windows out and start on welding some panels in, then i can finish the inside walls and roof.
Had a few dramas with the van this week, alternator died so have an 85amp bosch in now instead of the 70amp mitsubishi P.O.S.
Also replaced all radiator hoses and belts for good measure.
Sorry not much of an update but ill get my act together on the weekend
Cheers
Jay
hellovapano
Re: Hellovapano
Post by vanner065 on 23/6/2011, 4:10 pm
well done Jay, keep up the good work
Re: Hellovapano
